Topic: Need some ID help (Read 1222 times) previous topic - next topic
Need some ID help
I purchased what I thought was a HO upper intake off of ebay. I recently learned that under the engine plate was suposed to be the letters "HO" under there. Mine does not. It also still has a 55mm throttlebody and EGR spacer opening. It was my understanding that an HO opening was larger than 55mm. Did I get taken for a ride here? Can you guys tell me if my info is correct?
Re: Need some ID help
Yes there is are two letters cast into the intake that say H.O.
as for the opening i'm almost positive that it is bigger and yes the throttle body should be bigger than the one on the SO.
Ok, so Im a big dummy! Anybody want a SO intake?
do you want a ho and 65mm throttle body? i got both for sale ill take 35 for both if you want them
i can take a pic of them if you want and yes they are HO not SO
Quote from: armyguy298
No, but do you want buy an HO upper?
