Topic: Removing harmonic balancer... (Read 1513 times) previous topic - next topic
I just got to the point of removing the retaining bolt for the harmonic balancer.  I got the pully off by locking the crankshaft by sticking a screwdriver through a hole in the drive plate like it says to do in my rebuild manual.  Ofcourse when I tried the same for removing the main bolt it just bent the hole in the driveplate I was using.  That doesn't make me happy.  In any case I'd like to find another way to lock the crankshaft so I can get the stupid bolt off.
Re: Removing harmonic balancer...
if I understand the ?  you could use a breaker bar so it is against the ground and bump the starter...be careful though
Uhh..maybe I should clarify.  The engine is out of the car right now.  I'm trying to get the bolt off the front of the crankshaft but I have no way to anchor the shaft so it won't turn.  Currently the transmission end of the shaft is bare.
just get an impact gun..
I have an impact gun but it's a cheap peace of  that'll never get that bolt off.
Put two of the bolts from the pulley back in the balancer (don't thread all the way in) and stick your favorite leverage device (big screwdriver, pipe, breaker bar...) between them with one hand and crank on the balancer bolt with the other. I have done it like this many many times.
There's an idea.  Thanks I'll try it.
Actually the idea of putting that much downward force on the front of the engine while it's on the stand really freaks me out.  Are you sure it's safe?
Then use something that applies a purely rotational force. Something like.... I dunno.... an impact gun! Cheap or not, don't say it won't work until you've actually tried it.
