Topic: Progress On My latest Project (Read 2685 times) previous topic - next topic
Cobra replica, chassis #4343RD.  Power will be from a Ford Motorsport block, Edelbrock heads and a Edel Victor jr intake. Custom ground cam, Holley 650 DP carb. Custom headers and side exhaust.  I have the chassis basically complete, just have to weld in some mounting tabs, etc.  Wheels are 17X8 and 17X11.  The front wheels in the photo won't be used.  John
Re: Progress On My latest Project
Cool... I have a freind with one ordered, but I can't remember which one it is. He's ordered it less engine and trans, gonna install a real 427 and Top Loader 4 speed(already has them).
thats beautiful man...i dream of one day building one...
~John~
Thanks, Guys!  I forgot to mention it has a IRS from a '89 TBird S/C, 3:55 track lock, custom axles and upper and lower control arms.  The tranny is a T5Z.  Everything on it is new, except for the gas tank and the rear dif housing, and that has been completely rebuilt.  All the brake compinents are new, PBR two piston calipers in the front, single piston in the rear.  I'm also using a Wilwood triple master cylinder assembly, (hyd clutch)  Steering is a 15:1 Flaming river rack and a modified early Corvette steering column in polished stainless steel.  Coil overs are Eibach with Koni series 30 race shocks.  Horse power should be around 375, and with a curb weight of 2300 lbs it ought to scoot pretty good
Wow... You builded that?  :eek:
Two tumbs up man....    :headbang:
I'm already drooling just looking at the chassis....  :bowdown:  :bowdown:
Looks great John.  I have a friend who is also building one.  I spotted the 95 SC rear diff for him, and he plans to use a stroker 383 chevy and richmond 5-speed (chevy fan).  He plans to be putting out 500 hp.
If I had the $$$ and time to do one of these Factory Five Racers, I'd install a Turbo 2.3L w/5 speed.  Just imagine running a low 13/high 12 in the quarter, and still getting 30+ mpg on the highway. :D
If I had the $$$ and time to do one of these Factory Five Racers, I'd go the built 2.3T route with a 5-speed and 3.55 TC rear end.  Imagine running a low 13/high 12 in the quarter, and still getting 30+ mpg on the highway. :D
looks awesome so far.. great job
Quote from: joefriday
Factory 5 can set them up for just about any engine, your friend should think about a Tremac instead of the Richmond.  There's a guy I read about that installed a Buick Grand national turbo engine in one.  It hauls A**.
one day. one day I will also have the time and money to build one.
looking good man, keep the updates (and pics) coming!
Quote from: Funky Cricket
Thanks!  They are not that expensive a kit.  The basic kit costs $12,990.  That, and a '87 and up Mustang to use for the running gear, will get you a running Cobra, and with a curb weight of around 2300 lbs, will out run just about anything on the road!  You just have to be careful to not go too wild on the options.  Alot of guys also do their own paint and bodywork which will save even more money.
