Topic: What year HO? (Read 1457 times) previous topic - next topic
What year HO?
I am going to swap an HO motor in to my 88 sport coupe and i know that mustangs switched to mass air after 88 but does that mean i have to find an 87 or 88 HO to use speed density or else convert to mass air with a 89 and up engine?  I have an HO speed density EEC already so i dont really want to convert to mass air right now but finding the right year engine may be a problem. Thanks
Andrew
Re: What year HO?
The year doesn't matter, a '93 HO will run just fine on '87-'88 Stang SD system.. As will a '88-'92 LSC Lincoln HO or a later Explorer 5.0.
Re: What year HO?
I beleive mechanically all the engines are the same.
One thing you may look into is, I believe the <92 engines are 'forged' and the 92< are hyperwhatever (can't spell it)....
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
Re: What year HO?
late92-93 hyper/87-early92 forged.
Re: What year HO?
hypereutectic
adj.  Having the minor component present in a larger amount than in the eutectic composition of the same components.
There. Everything you ever wanted to know about pistons.  :giggle:
Re: What year HO?
The minor component being silicon. Which makes the piston very strong, but in the event of failure it will shatter rather than bend. I would stick with forged pistons if you had a choice.
Re: What year HO?
Is there a way to tell if it is a early 92 or late 92 engine?(without looking at the car) I got a HO out of a 91 or 92 mustang(at first they said it was a 91 but on my reciept they wrote 92) with 87000 miles on it for $400. It doesnt really matter i guess if it is forged or not. The car was basically destroyed from the firewall back, from the accident it was in.
Andrew
Re: What year HO?
Look at the casting date on the passenger side of the block in the starter area.
The date will be a 3 or 4 digit alpha numeric code, with 1M1 decoding as Dec 1 '91 and a 2A11 being Jan 11 '92. Get the date and I'll decode it. This won't tell you when the engine was actually assembled, but usually it is within 2-3 weeks.
