Topic: smoke..... (Read 3465 times) previous topic - next topic
smoke.....
I noticed today that I have a slight amount of white smoke coming from my tail pipe does this mean my turbo is shot?  I have aproximatly 165k on the engine
Re: smoke.....
88turbo, sounds like its head gasket time.please dont shoot the messenger. do a compresion test on your cylinders. that should tell the tale.
Re: smoke.....
*strangles greg*  I just got done putting a head gasket in  second one in two months thats not what I want to hear......  :nono:  the last one was last weekend dont tell me its blown
Re: smoke.....
alright, take it easy, did you have the head checked for flatness and or milled down a touch?if the exhaust smells a little sweet its coolant. maybe a crack somewhere you missed.
Re: smoke.....
no harm meant.  checked the head with a straight edge and was ok  the smoke is oil  but it only does it once in a while.  so theres where I am thinking that the turbo is on its way out the door.  when dads turbo went it smoked alot worse.
Re: smoke.....
dont have a ton of exp. with turbos, white oily smoke cant be good though. glad its not the head gasket.
Re: smoke.....
Michigan, 30 miles west of the motor city
Re: smoke.....
white smoke from oil ?! every time i've had oil smoke ( trust me i own a lot of oldies, 75 dodge pickup with 200K miles still running) and my turbo stang, that leaks oil into the exhaust housing, makes a nice pretty blue smoke...but the thing is....it makes lots of it,
but yours could be leaking into the compresser side, take of your charge pipe, and wipe the inside clean with a white paper towel, the see if it's oily....you may be getting into boost, and have the oil burn through the whole motor before you notice it ...
Re: smoke.....
I'll give that a try but from what I have read alittle oil is normal.  wouldnt hurt anything to try never know with my luck though lets not go into that one though....
Re: smoke.....
had the I/C off today and noticed a bit of oil on my lower hose.  I think its time for a turbo swap.  plus its starting to get a bit weak
Re: smoke.....
could just be bad valve stem seals, if it only smokes on start up or long lights....
Re: smoke.....
Quote from: BogusSVO
changed turbo's and it no longer smokes.  but now it doesnt want to accelerate with or without boost.  any ideas?  new tps, new plugs/wires, new rotor, cleaned connections inside dist, timing set at 10* btdc  I'm lost unless the tps needs adjusting
Re: smoke.....
is the waste gate actuator working properly? the new turbo you put on was it a new or used one? did ya plumb the vac line to the waste gate the right way?
