Topic: Springs front end 2 high (Read 9477 times) previous topic - next topic
Re: Springs front end 2 high
Reply #45
Quote from: JeremyB
The spring rate can change a bit, due to dimensional changes during heat treat, but that is something that has to be dealt with and designed for.
That was my point he could have one that was not treated at all which means its going to compress more that the other. Which inturn means it has a different spring rate. Or the other sat in their oven too long and turned so hard it will not compress.
And as for designing for it. It looks like he may have gotten a cheap pair of springs he said they were Ultra. I personal have never heard of them. So if they are a new company they could have a quality control issue.
Reply #47
The 8658 is the v8 spring, it has an install height of 11.75"
The 8606 is a HD V6 spring with an install height of 11"
Spring rate can also vary even when springs appear identical.  Check with a parts store for the Moog spring catalog, specs are all in the back...
Reply #48
I would trim 1 coil off of it . I done correctly it will have no ill effects.
IF he was to cut/Heat  it with a torch to lower the ride height  it could cause real big issuse with the heat tempering of the spring itself and cause sagging and spring failure later on.
Reply #49
My coil springs are covered in black vinyl.  I am no chemist or engineer but, it seems like the vinyl would melt off:flame: . Would that matter long term?
Reply #50
Quote from: thunderblunder
It could if it got too hot.
