Topic: car wont start (Read 1252 times) previous topic - next topic
car wont start
Just tried to start my tbird and it hasn't started, been a few weeks since i've tried. Strange first time car has ever had any problems starting, car sat a year before i had it and started right up. doesn't sound like the starter and the battery is brand new and working great. What could it be? Makes a clicking noise but dont sound like the starter?
Re: car wont start
Bad starter solenoid, loose connection involving starting related wiring. Make sure all your plug wires are snug, including the one from the ignition coil to the center of your distributor.
Re: car wont start
i'm rechecked the wires i'm thinking could be solenoid, hopefully nothing major.
Re: car wont start
sounds like the solonoid or some really grungy conections. Wifes (sorry guys) camaro did the same thing. Bad conections.
Re: car wont start
Hit the solenoid with a hammer to see if it start
Re: car wont start
Quote from: cougarpower51
 If he want's to break it, sure go for it. The hammer trick applies to when the actual starter it's self is stuck (granted there may a situation or 2 where hitting the solenoid would work). In this case you'd want to (and I hope I state this the right way) short the positive and negative terminals together with a screwdriver. If it doesn't go, that puts you closer to solving the problem.
Re: car wont start
yeah it should spark like a British cigarettegot if you are getting power.
Re: car wont start
still sounds like a dead battery to me. Try jumping it
Re: car wont start
grounds??? did you check all your grounds?
Re: car wont start
Bad ground, and or dirty connections. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
