Topic: i love homemade parts (Read 1674 times) previous topic - next topic
yesterday, i finally made myself an adjustable fuel pressure regulator, i just need to borrow a gauge now
Re: i love homemade parts
How in the heck did you make one?  Drill and tap a screw into a fixed version?  Hope it don't leak!
V6->V8HO 88 LS
5.0L V8 87 XR7
its a CFI fuel pressure regulator, those are adjustable from the factory, and i added the vacume reference nipple to it, and i had to fill a hole inside the adjusting screw, threw a few coats of paint on it, and its all done
I believe Scott posted a way to do this a while back.
is that where you got your inspiration or is your way a different method?
What's the purpose of this modification?
Quote from: Paul Flockhart
i remember Chris came across the fact that the CFI fuel pressure regulator was adjustable from the factory, Chris and Scott used it on their CFI cars, ive modded it to use it on my TC and my 5.0  if/when it makes it into the red bird
Quote from: JeremyB
the point of this modification is to take an adjustable fuel pressure regulator from a CFI car, and make it functonal on a full EFI car
Quote from: Tbird232ci
Ok, I thought you were going to put it back on a CFI engine.
So what are you gonna crank the pressure up to?
hey, nice amp :-P oh yeah and the fpr :D
how did you add the vacuum nipple?
Quote from: 87thunderbirdBlackJack
actually, the amp is a big time POS, but...it works, the amp hides the potential of the guitars i have
Quote from: 30thtbird
basically, i took a vacume nipple, and i hacksawed just the nipple part off, drill a hole slightly smaller than the nipple, so where i needed a small hammer to pound it in, pulled it out, threw some JB weld on it, hammered it in, and added some around the edges
when i get my hands on another CFI regulator, ill do a write up if anyone is interested
probably going to be 41#'s base pressure, since the cars run slightly lean stock, and im running more boost, id rather run slightly rich than slightly lean
thanks for the info.
Good job man.  I love the inovation.  Jason.
got my holley cranked up to like 45. but need more pump.  you'll like the extra fule. looks good man. but you really have to much time on ur hands sometimes.  hope the jb weld holds up.  did you use the 15 min or the 15 hour weld. im finding the 15 hour weld isnt working much for me .
i honestly dont know what it is...my friend just kinda left it at my house
building it only took 10 minutes, since i knew all what i needed, the longest part was waiting for the JB weld to dry, and the paint to cure
