Topic: M90 on a CARBED 5.0 PICS (finally here) (Read 3025 times) previous topic - next topic
sorry it took so long guys.. Hope you enjoy... lotz of work still to be done (bodywork). Took awhile to get everything right , had to make a custom intake for the blower to fit on the edelbrock intake , then I had to make sure it cleared the distributer, , had to make a custom intake for the carb to sit on as well ,, it was said that I couldnt do this on a 5.0 from other forums.. But as you can see , hard work and patience pays off.. Hope you guys like it.. any questions let me know.. I wonder if I clean it all up ,do the body work , if this thing can make it in MM&FF.. LOL
Re: M90 on a CARBED 5.0 PICS (finally here)
That slick looking.
But I have two words "Mad Max"
that is f-ing bad. How long until it is functional? I kinda wanna see where this goes.
Wow, i'm impressed. Not many would have taken on the challange. :D
thanks guys, its only need the carb linkage hooked up and its all done.. I have the hilbourne blower scoop for it as well.. As soon as its started up , i'll get some sound clips too, maybe even a little burnout for yeah too.. :)
i have more photos aswell, if you guys want more.\
how big is ur hood gonna be man. i like it but that will not be streetable. with a hood on it. kinda sucks. but good job
i have to say, i honestly didnt think youd get it together, great job so far, cant wait to hear how it runs
Quote from: ONEpissedOFFstang
Yeah a few good close ups would be killer. I'd like to see how that intake is setup.
Quote from: nirvanagod
 :stupid:
1979 Ford Fairmont
[/B]
Quote from: 5ohbird
:stupid:
Hey now!!!!  :D  :hick:
Thanks guys, more pics coming up, and to cougarcoupe88 , thats the hood im using , its a 5 1/2 inch cowl and the hilbourne scoop goes on aswell.. TBIRD232ci , have some faith in me man ! LOL .
How do you put oil in the case with the unit upside down?  I take it you fill it before you put it on.
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Hmm while I respect the fabrication I don't like how far it sits off the engine.  If you had built the lower intake ( i know a big pain in the ass)  You could have got it down low like a 3.8 does.  Those sharp bends look like they will hamper performance.
Congratulations, you shut some mouths....
 I like the Fabrication, good work man.
(EDIT) mmm, wait a moment, that means....can we build a Carbed 3.8 with the M90 ?
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
