Topic: HO computer (Read 1343 times) previous topic - next topic
HO computer
anyone have a speed density HO computer they would like to get rid of????
is the 86 ho cam any diff than 87-93?? reason being my brother-in-law just gave me his cam out of his 86,was going to the auto fair in sept. to try and find upper with 60mm, egr,19# inj.  thanks, Joe
Re: HO computer
HO cam is different from 86 to 87 and up.
Re: HO computer
I have an HO computer from a 91 Mark VII.
Re: HO computer
Quote from: dominator
Maybe, but not enough to worry about(Ford Racing catalogues don't say there is, or isn't)... Actually there are small differences in some of the later years as well.
Since you have it, use it. My '86GT Stang would run 14.5s on 2.3 60ft times with only a 2 1/2" Cat back system. I also inst under drive pulleys and 1.7 rockers... Definatly gave it more power, but made it almost impossible to launch on the shiznitty street tires I was using.
Re: HO computer
slamedcat, is that mark computer a speed density HO?? if so how much?? so you all think i should feel a difference with the cam, upper etc. i already have true duel, no cats and flows, need to get a set of headers,  thanks
Re: HO computer
Yes it is a speed density computer. How does $25 plus what ever shipping would cost sound.
