Topic: 83 3.8 V-6 (Read 1466 times) previous topic - next topic
83 3.8 V-6
Guys the hp numbers on this motor are pathetic.  What can possibly be done to get this motor in the 200 hp range?  I've heard there are simply not many aftermarket options out there for this motor.  Also, I'm in California, and you guys all know about the smog laws out here. :disappoin
Re: 83 3.8 V-6
You could always go to a mustang v-6 board. They make about 190 to begin with. You could always rebuild it, increase the bore. Then you could of corse throw a super on it. Regular honeing and porting. Specially of the heads, I think this is the biggest problem with hp. I know it dosent breath good. You could always convert over to EFI using a donor car, (dunno about the calif part) or at the very least, if it is cfi(ignore my ignorance) then you can do stupid little things like get the cfi unit off of a 5.0.
Re: 83 3.8 V-6
After market performance parts do not exist for this era of the V-6.  To get a power increase you'll have to go the traditional route and bore the block out.  I'd go 40 over bore, get a mild cam, oversized pistons, blueprint and balance everything, work the heads, go for some exhaust headers, roller rockers.
Also you'll need to replace all of the engine sensors, the MAP sensor, throttle body, the entire nine yards.
Do it up and  the nay-sayers!
Chris
Re: 83 3.8 V-6
I think the '83 3.8 has a carb. on it. I haven't a clue if it is feedback or not, but you have more options with the carb. than CFI. Like Chris said, you can add a cam, port the heads, new exhaust, etc... I'm not sure how hard it'll be to pass smog though. Either way, you won't be making 200 hp with the engine currently in the car unless you go gonzo.
If you have CFI, you're screwed. Do not pass go, do not collect $200.
The most appealing option is swapping in a Mustang 3.8L. You'll have to run a new harness and deal with all sorts of swap issues, but you'll end up with a pretty decent engine that makes almost 200 hp stock. The newer 3.8s get good gas mileage too.
Now, if you don't have any sentimental attachment to 3.8 liters of swept volume, swap in a 5.0 (Yes, someone had to mention this option).
Re: 83 3.8 V-6
dont go more than .030 over on a 3.8L, i wouldnt even want to bore one out to begin with, there isnt much meat in the heads and block between the cooling jackets and the combustion chamber, leaving less clamping space on the headgasket, meaning its more likely to give you issues
since you have a carb, you can pick up another carb, something a littler spicier, a decent Holley 350cfm would probably be decent enough im guessing, along with a full exhaust
other than that, there isnt much more you can do to your engine, you can put a cam in it, you can port heads, you can extrude hone the intake, but the power gains dont justify the cost
Re: 83 3.8 V-6
My block is 40 over bore without a hint of trouble.  Runs and sounds great.
Chris
Re: 83 3.8 V-6
.030, .040...both tic-tacs in a whale's mouth when trying to get 200hp from a carb'd 3.8.  ;)
.030 nets you 1.59% more cubes than stock
.040 nets you 2.12% more cubes than stock
Re: 83 3.8 V-6
Quote from: Chris1987LX
Chris
yet...
you also have to consider, that while you are modded, its not putting down the 200hp that LJS30 is after, more power equals more stress, and the 3.8L isnt designed to put down the 200hp, its designed to put down 120-140
Re: 83 3.8 V-6
Quote from: JeremyB
 :rollin:  :rollin:  :rollin:
permissioin to use that one day!!!!!!!!
1983 could be carb or cfi depending on the production month.  these years also had some vent windows also but mostly on the tbird from what ive seen.
Re: 83 3.8 V-6
Install a carbed 302.You could probably score one pretty cheap.
Re: 83 3.8 V-6
mmm, i want the 200 Hp too, but i dont know if its easier to get 200 Hp or 200KM/Hr in plain road....for sure , its going to cost you much...
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
