Topic: can't figure out why gas is leaking around injectors? (Read 2046 times) previous topic - next topic
well to make the story short, I just recently got another bird a couple months ago, and I started to replace some parts. When I got the car, I didn't think too much bout it, but everytime i parked it I always smelled gasoline fumes, I didn't think  it was a problem. Well after I started putting some parts on such as valve covers, plugs, wires, I found some liquid around the injectors, and below the upper intake. I thought maybe it was water at first, then i thought it couldn't be since I park it in the garage. So, I took a cloth and wiped it, and sure enough it was the smell of gas. Now, my question is, I have no clue where it could be leaking at? Any thoughts? Anyone had this problem? Or got any pointers? I'd appreciate it. Thanks!
Re: can't figure out why gas is leaking around injectors?
Did you knock the injectors around a little?  Or did you remove them or the runners at all?  I had the same problem with my 86 2.3 after I changed the cooling fan switch.  The O-rings on the injectors were just old and when I moved them they didn't seal right anymore.  So I would suggest getting an o-ring set from Autozone and replacing them.  That is what I did with mine and no more leaking.
Jim
86 2.3 Turbo
They often leak on the body of the inector where it is crimped together. If the "O" ring kit doesn't fix it, you'll have to replace the leaking injector(s).
