Topic: ed water.....*HELP* (Read 1150 times) previous topic - next topic
ed water.....*HELP*
So I *get* to do a water pump in my v-6 car. I have already bought it, any surprises along the way? Will I need a pulley puller or would I be okay to use the hammer(figuratively of course  ;) ). What all will I have to take off/put back on. Its a 87 which means its cfi. thanks guys.
Re: ed water.....
most of the front end accessories need to come off, the fan, shroud, pulley, that stuff
no puller needed
Re: ed water.....
You're going to break 3 of the double-ended bolts that hold it on due to corrosion, you won't know what size they're supposed to be, the Ford dealer won't know, you'll search this site and find nothing, then the entire Internet and find nothing, then you'll just sit and cry for a few hours before calling the wrecker to take it away and crush it.
Don't forget to put sealant on the threads of this bolt:
Re: ed water.....
anyway you could tell me what size they are?
Re: ed water.....
just take a good one in with you to the auto parts store, the advance auto's around here have this neat litle thing where your thread your bolt into it, and find the proper thread, then you just need to know length
and yes, definatly put thread sealant on the one MasterBlaster has highlighted, i forgot to, and was wondering why i was leaking coolant
Re: ed water.....
Quote from: Tbird232ci
no puller needed
Don't you need to pull the PS pulley to remove the driver's accessory bracket?
I can't remember. I may change my water pump this afternoon.
Soon the most expensive A/C retrofit EVAR!!1! will be complete.
Re: ed water.....
i didnt mine without a puller, i dont think i even remotely needed one
Re: ed water.....
hey yeah I missed a bolt and pulled alittle too hard. long story short, I can see the distributor gear through were to water pump goes. When jb weld says engine blocks, how good is that. I am pretty much screwed here. I will have to take a picture. I cracked it on the bolt that I didnt realize had a nut thingy on it. How the hell can the water pump be buffer then the engine block? ed v-6's. This may be something to junk the car over.
