Topic: lakewood 70/30 or 90/10 fit 88 tbird? (Read 2152 times) previous topic - next topic
like the title says
i bought some mustang rear shocks, and found out they were too short. i just wanted to know if this is the case for the front struts.
btw- im talking about the 79-93 struts
or is it better to use the sn95's?
1979 Ford Fairmont
[/B]
Re: lakewood 70/30 or 90/10 fit 88 tbird?
yes the fronts will work
Short answer, NO.  Long answer, YES, BUT, you will have to run mustang gt/lx or turbo coupe front brakes...this is because of the difference in thicknesses of the spindles.  The 3.8L and 5.0L t-birds as well as 4-cyl 'stangs all use the same front brakes and the spindles are too wide at the strut mounting point when compared to the turbo coupe or 'stang gt/lx spindles.  IF you decided to swap out to the larger style brakes, PM me, I just did the upgrade a few months ago and could walk you through step by step.
Good luck,
Don
Quote from: Sick88Tbird
Good luck,
Don
lakewoods come with a set of shims for the narrower 5.0/3.8 spindles
or they used to  :hick:
Mustang shocks can be made to fit with a simple modification to the mounting brackets. Here's a thread on the subject:
http://www.foxtbirdcougarforums.com/showthread.php?t=2617
Quote from: SLEEPER T-BIRD 87
I see...I was unaware of that.  :bowdown:
lol
