Topic: Converting to 5 lug(common i know) (Read 2101 times) previous topic - next topic
If i take the rear end and from hub assembly out of an 85 ranger can i swap it over to my 84 cougar. There will probably be a little complication i would expect. But would this be a way to do it?
Re: Converting to 5 lug(common i know)
The rear end will not bolt in - the Ranger uses leaf springs while your Cougar has a four-link setup with coils. I believe you can use one of the axles (the axles are two different lengths on Rangers) but the whole thing is a no-go.
I think from now on....all rear end swap questions should be redirected to "I'm gay as hell"......he should be able to provide some interesting feedback....... ;-)
What about the front? Would they swap over?
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
for the front you need to use 89-91 ford aerostar front rotors  have the diameter cut down .120 thou "any brake shop can do this on any brake lathe"
for the rear i would suggest having them redrilled for the 5 on 4.5 bolt cirlce 1any competent machine shop can do this also
than run ranger drums > 9 inch drums
or have the factory ones redrilled >10 inch drum
