Topic: new engine 5.0 ho (Read 1550 times) previous topic - next topic
new engine 5.0 ho
hy guys y buy a engine 5.0ho 1992 tbird.y wantto put this engine in my cougard xr7 87 (5.0) give me an answer please thanks.
Re: new engine 5.0 ho
Does your i key type y's instead? :dunno:
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Aww, give him a break.
Another Quebecois has joined the board.
Welcome, and here's a present...  :ies:  :ies:  :ies:
Quote from: danyboy
if by this you mean:
Hi guys. If I buy a 1992 tbird 5.0, would it fit into my 1987 cougar xr7? I really need to know thanks,
If that sounded better, then yes it would fit. Its only going to be about 50 hp better then what you have stock, where you could do a full H.O. conversion using cool cats and get an extra 25.
I think the 5.0 in '91 to '93 t-birds and cougars only has 200 hp.
 and 275 ft. pounds of torque. They are tuned down versions of '94
 to '95 mustang 5.0s; I read its just a camshaft diference.
where as the 94 to 95 mustangs have all the same accessories and got less tourqe and only 25 hp more.
It will fit, but you'll need a lot of your orignal 5.0 and '87-'93 Mustang pieces to make it work... For instance...
Upper intake and throttle body are different than the Fox cars(you may be able to work  it out).
Will be a lot easier to use your dist(and all wiring), as the '92 has a divorced module dist.
You'll need a better(true duals with headers) exaust system, The HO won't make much more power through a stock '87 system than the original engine.
You'll need a computer from a '87-'88 Mustang(speed densety), or '89-'93 if you want to do some wiring changes and go with mass air... You could use the '92 Bird EEC(not reccomended) but it will require additional changes the Stang computers do not. Also '87-'92 Lincoln EECs can be used...
EDIT Also the front accessories & timing cover are totally different, will be easiest to swap to the '87 pieces...
