Topic: 350 big block or 396 (Read 2750 times) previous topic - next topic
is it possible to swap in my 1988 tbird a 350 big block or a 396?? I am not sure because its a chevy engine... can someone clear it for me.. thank u
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Re: 350 big block or 396
there is no such thing as a chevy 350 big block, have fun with that
you can put any engine in any car, just need to have fabwork done
why do you want a chevy engine?
umm there is such thing man.. maybe i just go my words mixed up but so it is possible.. thanks a million.. 0o0o because i really want power in my ride.. i dunt think a standard 5.0 will do it.. do you have any suggestions?
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
you could easily make around the same power in a 5.0. If you are that worried about it, get a 302 with a kit and make it a 347. Then you have an engine with 351 internals and the weight of a 5.0 with lots of power.
o0o i meant long block my fault man.. o0o thanks alot for da info Haystack :)
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Since when was there a Chevy 350 big block? There are Oldsmobile 350's, Pontiac 350's and Buick 350's, but I've never heard of a 350 big block. You're probably thinking of the Olds 350 "rocket", popular in the late 70's. It's a dog.
As for puttinig a Chevy engine into a Ford, I'm against it not only in prinl but in practicality - a 5.0 will easily make as much or more power than any 350 ever hoped to and it's much lighter, and will bolt right into your car and onto your tranny (if you don't already have one in there). The aftermarket support for the 5.0 is enormous as well.
If a big block floats your boat a 429/460 will fit your engine bay with readily available adapters (there are a few members of this board who have done it) and again will easily make as much or more power than a Brand X big block.
...and a long block is simply an engine with cylinder heads on it. If you've got a running car you've got a long block in it already. A short block is a bare block with only the crank, rods, pistons and cam installed.
ok then wat can i do to my stock 5.0 then to make it have more power then a 350 since you said its possible.. I would gladly appreciate some knowledge plz...
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
the power you make depends on the money youre willing to spend
youre going to need to convert to HO, using an HO computer and injectors, then you can go over to trick flow, or holley that sells heads/cam/intake kits, and just put it together and have it tuned
how do i go over to trick flow or holley.. i dunno wat that is
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
summitracing.com
Trick Flow and Holley are both brand names, they are distributed by most performance shops, Summit Racing, and Jegs
o0o thanks alot im familiar with summit racing..
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
you are not "familiar" with summit racing. You heard thier name on a show once.
If you were "familiar" with summit racing you would know what kits are out there for a 5.0, cause they have a huge section under "mustang" or "Ford" that would have the products mentioned above.
you can't just ask, "me want m0r3 p0\/\/3r, tell me how". You have to "read" and "research" on what is out there and decide what you want to do.
magazines, forums (please read them first, before posting, it's only polite), AND asking the same question repeatedly won't net you different answers.
Please read the following sites for basic information.
http://www.coolcats.net
http://www.google.com
Just sell your Tbird and buy a camaro with a "350 big block" and you will be happy. ;)  :crazy:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
