Topic: alcohol anyone? (Read 2400 times) previous topic - next topic
Re: alcohol anyone?
Methanol = wood alcohol.. the stuff you don't drink unless your last name is "Dukakis"
Ethanol = grain alcohol.. the stuff you drink if you're into that sort of thing
Yes, I believe methanol is the one usually used in fuel applications.
Re: alcohol anyone?
Methonal is what the indy cars use, also some drag race cars. ;)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: alcohol anyone?
what ever hapenned to Mohawk Gas stations w/ there ethanol blended gas?
Re: alcohol anyone?
the reason I ask is because we have a barrel of methanol at the shop where I work.  any mods that I would have to do to run some of it my car?
Re: alcohol anyone?
almost all gas stations in minnesota run 10% ethanol even in the 93 octane but there are a few that have non-oxygenated fuel cuz the ethanol is hard on the collector cars and it goes stale alot faster
Re: alcohol anyone?
*Going at the gaz station*
Can you please fill my car?
I'd also take a Pint for me please... :giggle:
Once i saw a Bus that was part of an environmental project which was running with Ethanol (If i remember right)... It was Corn based Fuel.
Re: alcohol anyone?
Around here (Iowa) most of the city and state cars are run on 85% ethanol.  We have more corn that we know what to do with, so might as well pump some into our gas tanks.  The ethanol is cheaper here, too.  Only by 5 or 10 cents, but it's a difference.  I won't run the  in my motorcycle, but the car runs pretty well with it.
1987 Thunderbird 3.8. Sold :(
Re: alcohol anyone?
in most cases you don't need to do anything to run ethanol or ethonal blends in your car.
Methonal on the other hand is a bit more potent and should only be run in cars that are race fuel ready.
Michigan runs 10% ethanol, it is amazing that people are "oh no we need more oil.." but yet we burn in the the fields millions of tons of biomass that could be come ethanol fuels if they would just build a couple refineries... but that is all, i'll stop ranting now... (i wouldn't have to rant if I wasn't driving 120 miles + every day with 2.50/gal gas prices.. grrr..)
Re: alcohol anyone?
Quote from: Rwolf
They all became Husky's, which also have ethanol blended gas.
Re: alcohol anyone?
we dont get corn fuel here in ohio.
Most new cars have an option to be flex fuel.  On Fords they have the little tree and road square plaque on the side or the tailgate for trucks.  The 10% blend I believe is safe for any vehicle but for high blends the cars have to be flex fuel equiped because the ethbuttstuff will destroy fuel pumps, injectors and conventional rubber.
