Topic: passenger seat track to driver's seat? (Read 3086 times) previous topic - next topic
Could I do this?
I'd like to convert my driver's seat to a regular non-power track (and maybe ditch some weight in the process). I have a manual passenger seat track from an '84 bird, could I use that? Or, should I just take the driver's side track from my '90 mustang?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Re: passenger seat track to driver's seat?
Wouldn't you have problems with the seat belt brackets?
I think you should swap the tracks from the Mustang.
seat belt brackets? They aren't attached to the seats...?
Anyway. Maybe I should just steal the track out of my mustang, it's not looking like it will ever be driven again anyway.
Garrett H.
Exhaust sound clip
Another clip
They aren't?
I must be confusing the Fox and MN12 tracks...
The part of the seat belt that the belt clicks into is fastened to the seat track on a fox. ;)  I think someone on here said the Mustang tracks bolt to the floor different than the Tbirds/Cougars. :dunno:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
You mean the belt "buckle" as I guess you would call it?
No, it's bolted to the transmission tunnel in both my mustang and my thunderbird.
Anyway I'll have to look at the tracks and see what the difference is.
Garrett H.
Exhaust sound clip
Another clip
Doh! You guys were right about the buckle. It is attached to the seat track on my bird...I thought it was the same as my mustang, which has it bolted to the transmission tunnel.
And the tracks are different where they bolt to the floor between the thunderbird and mustang. Ah well, so much for that idea...
Garrett H.
Exhaust sound clip
Another clip
I have a 1986 mercury cougar and the seat switch doesn't work. I am not sure if i just need to get a just a Seat Motor or a Reclining Seat Motor. Does anyone know?
