Topic: help unscrew me please...(removal of power seats) (Read 2414 times) previous topic - next topic
hey guys...and gals. ive come into a delema. i need to remove some turbo coupe seats asap. the problem is that i had moved the seats all the wat back and down to work on the car. i never removed the rear bolts for the seats. :slap:  all the electrical in the car has been either cut or yanked. so now i cant move the seats forward to get to the back bolts. :shoothead  is there any way i could jump the controle switch to move them back to the front position or am i screwed? :dunno:  id greatly appreciate any help ...thanks again guys...john
~John~
Re: help unscrew me please...(removal of power seats)
Is the seat wiring harness intact (between the switches and the seats)? If so you can connect power to the black wire with white stripe at the switches, and ground to the solid black wire. This should get you power to move the seats around...
thanks mans...worked pissah...thanks again...john
~John~
