Topic: Fog lamps for 87-88 non-T/C Thunderbirds (Read 4910 times) previous topic - next topic
I just wanted to throw this out there. If you have an 87-88 non-Turbo Coupe like mine, there is a set of fog lamps you can get that look stock and give a good beam pattern. They're OEM 1993 Chevy Camaro fog lamps. The fit is snug, but they do fit, and they look better on the T-Bird than they do on the Camaro. They look like they were made for the car.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Re: Fog lamps for 87-88 non-T/C Thunderbirds
Any better options for different bulbs with that setup?
Thanks for sharing the find!
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
At the moment I have HID bulbs for those lenses but I also have a set of LED's for them. Since they're OEM housings anything for a 1993 Camaro will work. I actually like the look of them since they give it a sleeker, more modern look especially with the smooth hood. If someone offered me free a T/C air dam with fogs I'd keep what I have. The only annoying thing is people keep mistaking it for an '89 instead of '87.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
