Topic: Factory equalizer upgrade (Read 3412 times) previous topic - next topic
Picked up a factory Ford equalizer...the wiring seems straightforward to me.  I understand that the wiring harness was different with a factory-equipped car...but if I spliced into the power/ground/backlighting from the radio, then spliced into the signal output wires (between the radio and the amplifier), in theory it should work, no?  It would just be modifying the sound signals on their way to the amp/speakers?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
