Topic: 1988 V6 Running Rich / Rough Idle (Read 6509 times) previous topic - next topic
over the past few months my V6 has been getting noticeably worse MPG and is harder to start up when warm
(it always starts up when it's warm but it'll take a couple tries)
on a cold start it fires right up and runs good until it gets warmed up
I've checked all over for vacuum leaks and can't find any, I've also sprayed brake clean on every vacuum line and around the intake but none made a difference
I checked the fuel pressure with the vac line on and off the FPR and it's in spec and I don't smell gas from the FPR vac line
tested the coolant temp sensor resistance when it's cold and hot and it's in spec as well
would a partially stuck open EGR cause it to run rich and idle rough?
I don't believe the 88 V6 has an air temp sensor so I'm not sure what else to check that would cause this other than the ECU possibly going bad
1988 Thunderbird V6: all stock other than the radio
1985 Thunderbird TC: Stinger FMIC, Big R Stage 1 Turbo
Re: 1988 V6 Running Rich / Rough Idle
No codes?
Since you checked so many other things already i would check for possible failing TFI module since you have problem with warm start up.
No codes?
That’s a possibility but that wouldn’t explain why my MPGs are getting worse and why it’s running rich
It’s always started for me warm and it’s never died on me so I don’t suspect it’s the TFI
The ECU is probably the last thing on the list to worry about.
How old is the O2 sensor? When was the last tune-up?
