Topic: Problem with forum. (Read 8260 times) previous topic - next topic
Problem with forum.
When I try to open any section in the forum, there is nothing in it.
Re: Problem with forum.
My last post shows up, but that's it.
Try changing your theme/color.  I had the same issue about a month ago.
On the top left, you'll have a drop down for themes. I usually select the Storm Gray one or whatever it's called and everything shows up properly.
It's been working on a computer I'm on now, I changed the color on this one'now the drop down box is gone.
Apologies for all the trouble...this forum software is a little undercooked. The themes available are few and far between, and even though they're supposed to be vetted, sometimes they just don't feel like cooperating. Alex and I had a devil of a time getting this site moved up to PHP v8, so the themes might not be 100% compatible with that version. I continue to check for any updates and will install them when/if we get them.
I'm having the same trouble. I clicked on the dropdown and none of them show anything. The "Storm Cloud" is highlighted, but I can't click on it.
I had luck with going through my account settings, and finding where you can set the default theme. I set it to the grey and it's been defaulting to it every time I log in.
