Topic: Misfire - '88 TC (Read 26786 times) previous topic - next topic
Re: Misfire - '88 TC
Pulled the head off and the gasket popped between cylinder 2 & 3.
Head is back on and need to button up a few other items.
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
That sucks, especially since your spark plugs dont indicate a blown headgasket couldve been the issue.
It's actually pretty common. These things will blow the gasket between cylinders rather than between the cylinder and cooling jacket. The plus might just show rich, which will make you think it's an ignition problem.
Luckily, the 2.3L is pretty easy to yank the head off of. It's just heavy.
It actually showed lean!  I guess the wide band O2 sensor doesn't read raw fuel as rich.  It surprised me on the readings.
I used an engine hoist to lift and put the head back on!!!!  LOL
'21 F150 Powerboost
'17 Husqvarna TX300
