Topic: Stock rear brake drums (Read 5625 times) previous topic - next topic
1986 cougar xr7 2.3 turbo 5 speed! Original owner about 100 k on car. The rear brake drums are original factory from ford. When do u change them to new drums are there a miliage on-the drums, to change for new drums
Re: Stock rear brake drums
When they are less than 1/16 inch thick. Have you ever had them re-turned to smooth them up in the life of the car?
Places that do that work will tell if they are too thin and need replacing.  They check them with a micrometer.
No just all rear brake hardware ,shoes and wheel cyls drums original
86 xr7 should have the larger 10" drums. These were hard to find about 10nuears ago, if you can find a replacement set, I would pick them up.
Rock auto has them, I got a set from them last year.
https://www.rockauto.com/en/moreinfo.php?pk=11668393&cc=1198605&pt=1744&jsn=890
Original 1988 Cougar XR7 owner 200,000 miles and counting.
