Topic: So what's the possibility (Read 2814 times) previous topic - next topic
So I'm going to be doing the front where shortly, I was wondeirng what's the possibility of putting 275's on the front of the cougar.
How much space would it save me for putting 245's on the 9" cobras vs the 275's.  Anyone know what the dimension would be at the very top of the wheel?
Willpower is no match for Horsepower.
Re: So what's the possibility
hmm, with 9" fronts I think that it would rub alittle. I dunno about the fender though. Is it the stock offseted rims?
Quote from: Haystack
Stock cobra wheels yes, with the 275/40/17's.  With 99+ spindles and probably fox a-arms to bring it in a little bit.  I planned on removing the inner fender lip.
They will fit had them on my bird for a while now 17x9 cobra r's w/275/40/17 spoogeho 710's. you can also fit a 17x10.5 w315/35/17's on the rear with no rubbing i am running s95 offset wheels
Quote from: SLEEPER T-BIRD 87
So 275's on a 9" wide wheel will fit on the front?  I can imagine on lock to lock turns it will rub like crazy right?
Quote from: David
nope, no rubbing
 i do not have inner fender though
What kind of A-arms and spindles do you have on there?  Eric says he has rubbing with 8.5" wheels.
Can anyone else chime in on this subject?
Anyone have any info?
Quote from: David
stock a-arms, svo rotors, stock height , s95 offset wheels close to the strut but does not rub.
i also have a 10.5 wheel on the rear with no rubbing either
stock a-arms, svo rotors, mustang struts w/coilovers, s95 offset wheels
18x9, 245-45, tubular k-member fox mustang control arms and springs. :tg:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
