Topic: 83-86 Front and Rear Bumper Bright Insert - Need Suggestions (Read 6822 times) previous topic - next topic
So both of the bright / chrome inserts in the front and rear bumper covers on my 83 are getting the yellow look.  Being they are obsolete like most other trim parts on the car new ones are a no go.  Any suggestions on how to refurbish them?
Re: 83-86 Front and Rear Bumper Bright Insert - Need Suggestions
Didn’t the company Precision Trim Inc., use to make a trim moulding that would work?  Not sure if they even still exist. Also it seems someone on here found a chrome vinyl tape in the correct width years back and could be ordered in various length?
 S O L D
I vaguely remember reading here long ago someone buying some kind of chrome tape (for model cars i think)or something to redo this part since its not available anymore.
https://www.coolcats.net/restoring/#exterior
BUMPERS (FRONT AND REAR)
The bumper molding for your car (front and back) is formed into the bumper cover itself; it is not removable or replaceable. If the paint on the molding is faded or you see the yellow bumper cover material showing through, then it just needs a simple repaint—see Refinishing below.
The chrome strip—technically called a “rub strip”—is replaceable, however. Finding correct NOS rub strips is pretty much futile at this point, but there is an excellent substitute for them. Under the Sherman Brand, p/n 547-354, is a universal rub strip meant for a mid-1990s Grand Marquis. It is an identical profile and fit for our cars, both front and rear. The only caveat is that the pre-applied double-stick tape is actually on the wrong part of the rub strip. You may have to remove it and reapply using a good (3M) double-sided tape. And it’s missing the factory-style metal clips, which you really don’t need. But that’s it…otherwise it is 100% the same as what we had from the factory. We’ve seen it applied in person and it’s perfect. So this should be considered a permanent solution. You can find it on eBay, Summit Racing, or possibly Rock Auto.
Thanks to Matt for the info.
Found a couple more part numbers for it and are as follows:
1995-1997 MERCURY GRAND MARQUIS REAR BUMPER MOLDING
OEM#F5MY17C830A
PL#FO1157218
Thanks for the info and I am ordering a couple to redo both bumper covers.
