Topic: Autolamp Relay (Read 5392 times) previous topic - next topic
Autolamp Relay
Does anyone have a diagram of the location of the Autolamp relay ?
Is it one of the four under the dash, near the console ?
Thanks in advance !
Original 1988 Cougar XR7 owner 200,000 miles and counting.
Re: Autolamp Relay
From 87 EVTM.
Re: Autolamp Relay
Thank soo much !
You guys are awesome.
I may be an original owner but I am still learning.
Re: Autolamp Relay
Headlight Relay Installation
Hello, I know this is a frequent & old topic but I can’t find the link that further explains it.
Found what I think is the correct diagram for my 85 T-bird. Highlight’s.
Question is, Where on the vehicle does the GRN /Blk , and the RED/BLK branch off?
I am hoping the branch is closer to the headlights themselves, or at least under the hood, making the install of the relay’s consist of only Two.
Am I on the right path?
Thanks, John C.
Latest Find, 1985 FILA Style, 5 Spd. 4 Cyl. Turbo Coupe Thunderbird, Clean underside, Rough around the edges, well worthy of total restoration. A follow up to my 89 5.0 Mustang project.
Re: Autolamp Relay
EVTM says:
S115 & S116 location is,"L H Front Fender Apr0n." For cars without autolamp feature.
S115 location is, "Front of engine compartment." For cars with autolamp feature.
S116 location is, "Behind L H Headlamp."
Re: Autolamp Relay
Trimmed the diagram down to just the Turbo Coupe part.
Connector C286 is a gray 8 pin connector.  "LH front fender apr0n, near voltage regulator."
If you still have the 1G alternator with the external regulator.
Re: Autolamp Relay
OK, good news, I’m working in the right direction. Next step for me,
Physically locate the S116 High beam, & S115 l Low beam junction’s, and splice the Relay(s) into an accessible point prior to each junction.
2.3 came with an aftermarket Inter-cooler, runs good, needs some TLC for its full potential.
Re: Autolamp Relay
Might be easier to find Connector  C286
