Topic: 87-88 Poly motor mounts 5.0 Needed ASAP!!! (Read 1916 times) previous topic - next topic
Hi everyone.. I have a pair of Chuck W poly motor mounts that have been in my car for at least 10+ years and loved them.  Started my car up yesterday to do an oil change and found a pile of shredded poly chunks on the floor.  Upon inspection, found that both side engine mounts, the bushings disintegrated and crumbled when starting the engine.  I’m in a bind and need new ones or bushings that can be replaced.  Here are some pictures.  Please DM me if you know anyone that has a set.  This is for my 87 XR7
Thx
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
Re: 87-88 Poly motor mounts 5.0 Needed ASAP!!!
I replied to your other thread with the PN for the replacements.
