Topic: Rear tire sizes (Read 7174 times) previous topic - next topic
Rear tire sizes
Hey all, I thought this topic was beaten to death, but I can't seem to find the info any more since the site switch. Anyway, it's time for new tires on my bird and I think I may want to go wider. Have people ran 275/50r15s or 275/60r15s without rolling the fenders and retaining the quad shocks?
I can't decide between the 26" or the 28". I currently run 255/60r15s which are about 27. So if anyone has pics that would be very helpful.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Re: Rear tire sizes
Not that I will be much help but obviously you have 15" diameter wheels but what is the width, backspacing and offset?  If you are running a factory wheel let us know which one as someone may be running that same wheel and can chime in.
Re: Rear tire sizes
When I had my Sport in it's final configuration, I had 275/40/17 on the back. No rolling, but the tires were fairly close IIRC. Quad shocks are a no-go unless you come up with some funky weird offset wheels, but then you'll tire protruding and probably other issues..
I had mine on Bullit wheels from something like an '03, '04 Mustang. The fit was perfect, too. Fronts were 245/45 and also fit well, no rubbing etc.
As an aside and not much relevance here, those same wheels/tires are now on my '87 Stang notch and unless I did body work, the combo is about as big as can be stuffed in there. One thing about The Tbirds...you can put a little more tire under it and have some wiggle room.
Re: Rear tire sizes
I can't answer your question exactly, but I have a 275/35/18 on an 18x9 +35mm wheel. There is plenty of clearance to the fender lip and about a half inch to the quad shock.
You can kinda see the clearance to the fender lip in that picture.
Re: Rear tire sizes
Thanks guys. I am unsure of backspacing. I got the wheels used, so I would need to pull them and measure. I will say they appear pretty centered with about 3/4" between either the quads or the lip. Thanks for the pic Shawn. I think I may have enough clearance to pull it off.
Re: Rear tire sizes
 Shawn....with Bullitt wheels I couldn't run the quads LOL. And I would've, had they fit. I had a pair of fairly new ones.
I also had CHE arms, so losing the quads in my case wasn't much of an issue. Anyway...your TC looks good!
Re: Rear tire sizes
These wheels have an odd offset compared to what most people use on fox bodies.
Fox body Mustangs have far less room in the rear wheel wells, so they bring the tires in closer to the inner wheel well. If we ditch the quads and tail pipes, we can stuff a 10.5" wheel and a 315 in the rear.
Re: Rear tire sizes
You're right on the Fox Stangs. Those tires of mine don't leave much room. Can't remember how little the gap is between the tire and shock on mine, but it ain't much.
I miss having a Tbird. Might have to start looking again...
Re: Rear tire sizes
275/50r15s should fit great. I run 265/50 r 15s and I could of went wider. Rims 7 inch or wider.
https://tiresize.com/comparison/
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
