Topic: How to change the odometer reading Motorsport 140 speedo (Read 1676 times) previous topic - next topic
Does anyone know how to change the odometer reading on the Ford Motorsport gauges?  I've heard it is simple but I don't even know where to start.
BTW, I searched '140' and 'Motorsport' in the Technical sections.
Re: How to change the odometer reading Motorsport 140 speedo
You basically just have to partially pull the pin that the odometer numbers use as an axle, then carefully move the rollers to the correct order. Or, if you're like me, the whole thing will come apart and you'll have to figure out how get it all back together and working. You'll have a real fun time trying to get the numbers to line up properly with the odo window in the speedo face, BTW :D
