Topic: Brake Light in dash cluster (Read 1914 times) previous topic - next topic
I am curious if there is a switch attached to the E Brake system on my 1988 LX Thunderbird. I have moved the car a handful of times this spring, and the light would go out when releasing the E Brake. Last weekend the light did not go out. After setting and releasing multiple times and light not going out, I proceeded to roll car back and forth and then went for a ride. E Brake is definately releasing, car drove fine, fluid level in master cylinder is good, didnt come across any leaks under car. Thought I would ask the experts before poking around.
1988 LX, 306 with GT40P heads, Downs Upper Intake on Truck Lower, Powerdyne Supercharger and T5 swap.  Scavenger Hunt Build at it's best.
Re: Brake Light in dash cluster
Try pulling up on the e-brake pedal after you have released it. The switch for this is on the driver’s side above the kick panel and e-brake pedal. I had this happen to me once and if I recall, the brake pedal was sagging just enough to trigger the switch. I believe the switch position is slightly adjustable.
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
