Topic: Console difference? (Read 2833 times) previous topic - next topic
Console difference?
Is there a difference between the automatic console and the manual console other then the shifter cover?
:burnout:
Re: Console difference?
In the full length console cars like my '83 the only difference is the trim plate covers for the auto or stick.  I believe the 83-84 cars got the full consoles and the 85-88 cars could get the consolettes or full length.  I checked Eric's site and my years are correct - https://www.coolcats.net/modifying/console.html
The other thing that is missing is the manual transmission tunnel hump on the floor of the car if the car was not originally a stick car.  You don't have to have one to make it a stick car but they are very nice as it squares up the tunnel so the lower boot seals to the body.  Just in case you do not know what I am referring to here is what you can get for a Fox Mustang:
https://lmr.com/item/LRS-7277A-K/1979-93-Mustang-Manual-Transmission-Hump-Kit
To get one for our cars you have to remove one from a donor car.
It also gives bit more clearance above the trans/shifter. Things are pretty close in my manual-converted '83.
