Topic: These parts are up first (Read 1993 times) previous topic - next topic
Power antenna assy. with lower switch panel - $80.00
Black trunk carpet with spare cover and jack-$50.00
Marchal fog lights with brackets, switch and 8 spare bulbs- $325
Rear axle assy. with Auburn track lock and 3:45 gears, new breaks,axle bearings and seals, - $350
1983 TC cluster with tach - $85
Complete ac system - $250 ( currently swapped over to R134 and will freeze you out)
Full Gray Interior, power front seat,( piping coming out), manual passenger seat, gray rear bench , seat set -  $225
Loaded center console with fuel door release inside - $100
Trunk pop solenoid and switch - $45
Loaded black tilt steering column with cruise and ignition key- $125
Gray power window and door lock door panels complete with arm rest - $125 pr
will trade my power window regulators and motors for manual regs and crank handles
if you don't see it ask, if you want to make offers on anything shoot me a pm, a cage is going in the car so all this is coming out, gona use a fairmont steering column,
Re: These parts are up first
Still got any of it?
