Topic: dash swap, sn 95 into bird (Read 5059 times) previous topic - next topic
anyone done a dash swap?
Re: dash swap, sn 95 into bird
Yes, its pretty much identicle to the a fox mustang swap except you don't have to trim off the door handles. Ours are further back and do not interfere. The mn-12 cars use the same style steering wheel and column cover. The steering shaft a column is different. You have to trim a bit around the windshield.
so an MN12 dash will also go in?, The fairmont column looks like a direct bolt in, and if i understand you corectly the fox or sn 95 dash is a almost a bolt in too?
I was saying the column trim covers for an mn12. The mn-12 is completely different. All fox parts are built on the same structure so most parts interchange
got it, thank you very much for the info, very helpfull ;)  :smile:
