Topic: 4R70W in a 1988 Thunderbird. Shifter install.  (Read 6829 times) previous topic - next topic
So I wanted to make sure that i could keep the car stock looking on the interior and exterior. So know I am tackling the shifter. I tried to keep the stock shifter in the car but it was not working out well. My plan was to install a 99-04 Mustang shifter and make it sit well with the console and cover. Sounds easy but it takes some work. The 88 shifter mounts to a flat plate on the trans tunnel. A 2002 shifter mounts to the curvature of the Mustang floor. So since that was not working, off to the junk yard with a sawzall I went. I cut a big part of the floor out of a 2002 Mustang and started my modifications.
The Thunderbird shifter plate on the floor was screwed in and seam sealed to the trans tunnel. After getting that part out, I cleaned up the area and started to make the 2002 part fit onto a 1988 part. With a lot of tpuppies, fitting screwing around and modifying the console, I was able to get it all to fit and play nice.
:burnout:
Re: 4R70W in a 1988 Thunderbird. Shifter install.
I have more pics but it keeps coming up with errors every time I post. Maybe admin knows why?
:burnout:
Here are some more
:burnout:
I seem to not be able to add photos one after another. So I do stupid posts like this one.
:burnout:
And this is the completed look before it is all secured into place. I just need to figure out where I am going to run the harness for the quick 4 controller.
:burnout:
Looks like it belongs there.  Very nice.
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
That is what I wanted to go for. Nothing worse then someone seeing that it is not quite right. Tried to make it look as stock as possible.
:burnout:
Looks pretty good. Looking forward to seeing how it works out.
