Topic: Drivers to dual power seat upgrade. (Read 3313 times) previous topic - next topic
I was taking the interior apart in my bird for a couple reasons. One thing I noticed was I had power drivers seat but the wiring for a power passenger seat. Pulled the seats and carpet and found that the factory just tossed in an extra harness for a power seat and it was not plugged in. So I pulled the harness out and laid it out properly for my seat. I could not find where the harness plugged into on the passenger side for power and grounds. After some more research I noticed that the factory just shoved in two drivers side power seat harnesses and buried the other under the carpet. I figured that out by looking at the pin outs on the passenger side harness and found two wire were wired the same as the drivers.
So I am thinking I will make the extra harness pin properly for the passenger side and tap into the powers and grounds. The only thing I can not find is what the purple/yellow wire does in that harness.
:burnout:
Re: Drivers to dual power seat upgrade.
So I was successful at making two drivers side power seat harnesses into a passenger and driver power seats. All I had to do was tap into the power and grounds and then run a purple/orange wire between the two connectors. On the passenger side I had to swap two wires according to the EVTM.  I tested everything with my ohm meter to make sure all resistances were good. Now comes the task of putting it in and swapping the passenger seat track to power.
:burnout:
I have the passenger side power seat base if you need one.
I found a passenger power seat base at the local yard. I am going to make sure it works though!
:burnout:
