Topic: 2003/04 Cobra front springs (Read 8781 times) previous topic - next topic
I see that in a lot of posts that when you guys upgrade to newer front springs that you use 99 up Mustang GT springs. I have 2 sets of 2003 Cobra springs that I swapped from a coupe years ago. I think they are 300lb rated springs or something like that. Will these lower my bird plus keep the front stiff? I know my Cobra was not so comfy of a ride but that was not the purpose of owning a Terminator.
:burnout:
Re: 2003/04 Cobra front springs
I wish I had the answer. I'm interested in hearing replies. I use 1999 Mustang front springs, great ride and about a 2 inch drop.
'87 Mustang 2.3L 370 / 160
'87-93 Mustang 5.0 425-530 (progressive) / 200-300 (progressive)
'93 Mustang Cobra 425-530 (progressive) / 160
'93 Mustang Cobra R 750-850 (progressive) / 240-260 (progressive)
'94-95 Mustang Cobra 400 / 160
'95 SVT Cobra R P/N M-5310-R58; 700-850 (progressive) / P/N M-5560-R58; 200-260 (progressive) *Springs were supplied by Eibach
'96-98 Mustang Cobra 400-505 (progressive) / 165-265 (progressive)
'99-04 Mustang V6 OEM 400 / 190
'99-04 Mustang GT OEM 450 / 210
2000 SVT Cobra R P/N M-5310-R00; 800 / P/N M-5560-R00; 750 (IRS) *Springs were supplied by Eibach
2001 SVT Cobra OEM 500 / 470 (IRS)
2001 Bullitt P/N 1R3Z-5310-CA; 600 / P/N 1R3Z-5560-AA; 250
2003 Mach 1 P/N 3R3Z-5310-AA; 600 / P/N 3R3Z-5560-BB; 250
2003 SVT Cobra Conv. OEM 500 / 470 (IRS)
2003 SVT Cobra Coupe OEM 600 / 600 (IRS)
I have not verified these numbers but this list has been on the Mustang board for years and as far as I know it has been vetted.  Would have been great to also have had the new and uninstalled length so you could make a comparison but this is a lot of good info.
So a 600lb rating on the front compared to the 400-ish for the stock Thunderbird. I swapped in a 351W so that may just be the good spring to swap into the bird.
:burnout:
I'm using the 2003 Mach 1 springs front and back. I ended up putting a 1/4" shim on the front due to tire rubbing on road dips.
Was it rubbing due to tire/wheel selection or just because it was too low? When you say a 1/4" shim, do you mean wheel spacer or under the spring?
I would like to see a pic of the stance you have.
:burnout:
Yeah, 17x8 wheels with a 235(or 245)/45/15 (I think, whatever ratio get it close to 25-26" tall) were a little wide so it was kissing the inner part of the fender lip sometimes on dips. Yeah, aluminum spacer under the top of the spring - see picture below.
This is about what the stance is currently:
It may be a little lower in the back to accommodate launching at the dragstrip.
I've got 98 GT convertible springs all around with poly isolators and 26" tall tires. My car sits about like Cougar 5.0's. I don't have an issue with the tires rubbing the fenders on bumps but I have an aluminum headed 5.0, which is a bit lighter than a 351W based engine.
It looks like it only lowers the car slightly which is good. I see some cars on here with 16" rims and the cars are very low. Almost like no gap between the tire and top of the fender
:burnout:
The SN95 springs (GT, Mach 1, Bullit, Cobra) should lower it just enough to get rid of the 4X4 look but not slam it to the ground.
And that is what I want. I have some 17" rims to put on her. I like less 4x4 but not slammed. My work has these huge speed bumps that I want to make it over without killing my exhaust
:burnout:
Not to hi-jack the thread but I heard somewhere long ago that springs from a SN95 convertible were closer to spring rates on our cars? Anyone know if this is accurate? Maybe it’s just the rear springs?
 S O L D
Convertible SN95 rear springs are close. They are way shorter though. If you don't have adjustable height rear control arms the rear will be almost riding on the bump stops with SN95 convertible springs and stock control arms.
I didn’t know that. Maybe a dumb question but why are they shorter on convertibles?
 S O L D
