Topic: Ford switches to GM harness (Read 2466 times) previous topic - next topic
I'm trying to wire up my factory Ford 1988 Thunderbird multi-function (turn signal), dimmer, and headlight switches using a hod rod (GM) style harness. Wondering if anyone's done this on here and could offer me some help with it. I've been reading the EVTM and I think I've figured some of it out but am feeling pretty unsure about it. I'll keep working at it, but any help would be greatly appreciated. Thanks!
[ FORD MFS ]
[ C238 ]
3 LG/W - LEFT FRONT TURN LAMP > Lt Blue
9 LG/O - LEFT REAR TURN/STOP LAMPS > Yellow
507   - [DIMMER HARNESS] High beams > Lt Green
527R - [DIMMER HARNESS] Flash to pass > N/A
13 R/BK - [DIMMER HARNESS] Low beams > Tan
15 R/Y - [DIMMER HARNESS] Power > Lt Blue
[ C237 ]
5 O/LB - RIGHT REAR TURN/STOP LAMPS > Dk Green
2 W/LB - RIGHT FRONT TURN LAMP > Dk Blue
44 LB - FROM TURN SIGNAL FLASHER > Purple ???
385 W/R   - hazard flasher + out > brown ???
511 LG - stop light switch + out > white ???
[ FORD MAIN LIGHT SWITCH W/O AUTO LAMPS ]
38 BKO - Hot > Red
15 RY - Headlamps > Lt Blue
195 T/W   - Hot > Orange
14 BR - Park & Taillamps > Brown
19 LB/R - > Dash lights > Dk Green
[ GM HARNESS TURN SIGNAL WIRING ]
Lt Blue - Left front turn signal
Dk Blue - Right front turn signal
Brown - Hazard flasher
Purple - Turn signal flasher
Yellow - Left rear turn signal
Dk Green - Right rear turn signal
White - From stop light switch
[ GM HARNESS DIMMER WIRING ]
Lt Green   - High beam
Tan   - Low beam
Lt Blue - Power from headlight switch
[ GM HARNESS HEADLIGHT SWITCH WIRING ]
Red   - Battery feed
Orange - Power from tail light and park light fuse
Lt Blue - Dimmer switch
Brown - Tail & Park lights
Dk Green - To dash light fuse
Diagram of the GM wiring ...
Turn signals
turn-signal-wiring-diagram-third-level-stop-hazard-gm-schematic-data-everlasting-t.jpg
Re: Ford multi-function switch to GM harness
C238
507 Y  527 R  13 R/BK  and 15 R/Y  are the headlight dimmer switch and flash to pass switch. EVTM page 159
C113
6  Y/LG   from horn relay.
57 BK  to ground
151 LB/BK to speed control amplifier.
  6 Y/LG supplies the voltage (through the horn relay coil) to the speed control buttons.
pics
