Topic: T-Bird/Cougar Parts - Some Free (Read 1745 times) previous topic - next topic
I've got a bunch of stuff to clean out of the garage. Some of this stuff can be had for free. I'm also interested in trades for 5.0 parts, specifically decent valve covers, GT40P compatible headers, full buttstuffog V8 cluster, electric cooling fans, and mustang dual exhaust components.
- 7.5" Conventional 3.08 rear out of an 88' Cougar LS. Swapped it out recently for a limited slip unit from a TurboCoupe and no longer need it. FREE local pickup.
- (2) Stock 5.0/3.8 Starter Motors. FREE local pickup.
- 4 bolt spare wheel/tire. Tire is immaculate and original. $50 local pickup only.
- 14" wire hubcap. Great shape, no label on centercap. $20
- 5.0 XXX block and crank. Never bored over. Looks to be in good shape, just needs cleanup. $100 local pickup only.
- 5.0 Harmonic Balancer. Cleaned. $20
- Various 5.0 accessory drive components from various years. Power steering pumps, air pump, alternator, mounting brackets, pulleys. Inquire.
- Blue center console out of 86' Turbo Coupe. Decent shape. $50
- Stock 1987 5.0 Upper and Lower intakes, EGR block, and throttle body. Plaque missing. $40 takes all.
- Stock 1987 5.0 Computer. $20
- 1988 3.8 V6. Full motor assembly and associated wiring. Ran decent until car was parked after transmission failure. Did have some leaks and repaired oil pan. Needs to be pull out of my car but if someone wants to help me, its theirs for free.
- 1988 Stock V6 Exhaust System. Like new, installed shortly before car was parked. $75
- 1985 Stock V8 Motor Mounts. Cleaned and in good shape. $20
- Blue 1985-1988 Sun Visors. Fantastic shape. $40
I probably have more things I'm forgetting.
Hit me up! (240) 678-5016. Southern York County, PA
1988 Mercury Cougar LS
5.0HO + T5 Swap + Suspension/Brake Mods
