Topic: Well then...... That's news to me..... (Read 7724 times) previous topic - next topic
I was doing a little digging into EATC system operation and came across the following thread.....
http://www.foxtbirdcougarforums.com/index.php?topic=39114.msg451153#msg451153
I found a post in there that piqued my interest considerably.  Here it is....
Quote from: My10-80;451112
would it make a difference that I can still manually adjust the speed?
Ummmm, I dunno I'd suspect the controller I mentioned is OK if manual adj works...
May want to check EATC temp sensor mounted at heater core hose connector... It prevents blower from operating on automatic when engine is cold, then goes to full on once temp starts to rise... It's one of the things that pissed me off about the EATC system, as air was never warm enough when high speed activated(and part of reason why I specifically sought out my TC with a manual HVAC system)... Then you are talking about A/C, so again I dunno...
BTW there is also a cabin ambient temp sensor that plays a large roll in operation, it's mounted in dash above the Graphic EQ/storage well...
I'm sorry.....  WHAT? A cabin temp sensor?!!!!?????
 I never knew about this let alone noticed it when I've been messing about in that area....
Someone please educate me on it.
Re: Well then...... That's news to me.....
Well it's there. I've seen it when the radio surround trim is off. I haven't tried to remove it but the thing works, which is all that matters to me.
I'm curious about its operation more than anything else....  Meh.  Time to pony up for that shop manual I've been eyeballing anyway....
According to pages 108-109 of the 1988 EVTM there is an in car temp sensor in the dash as well as an ambient temp sensor in the evap case. So the system has two temperature sensors.
The dash one is what I'm interested in.
News to me  also.  I just knew about the one monitoring coolant temp to the heater core.
Mike
guys,
the trim around your radio & ash tray & eatc ,, at the top rolled in area of that piece of trim there is a cut out from the factory.
poke your finger into that approx 3/8'' x 1'' opening and you may find the j or k wire type temp sensor leads.
on my 20th the sensor is not there,, its on deeper into the innerds of the dash.  the factory wire would not reach its intended home.
Its used when you set your eatc to Auto,, the eatc will ramp the blower up and down on its own?
i did not know about an external temp sensor other than the one on the heater core
Been busy as heck.  Forgot all about this.  My shop manuals came in.  Time to research this.  I'll post when I can.
Please click on the two links.  They're pictures.  Haven't quite figured out how to insert the actual images from Google Drive on here yet.
https://drive.google.com/file/d/19Og6H_pz0fwbPkZmkHo8dYZQOxhOh8hl/view?usp=sharing
https://drive.google.com/file/d/19PDau6qmuW03rjb6roA6q8oj1_8p-yKl/view?usp=sharing
Sorry for the long wait.  I actually pulled the In-vehicle sensor today and cleaned it.  It was quite disgusting.
It may even be so bad that it no longer works.  I'm looking through the test procedures in the shop manual now.
Anyway, whether or not I'll need them does ANYONE actually know the part numbers for these or the Motorcraft numbers?  I know they're quite difficult to come by.
EATC ATC HVAC A/C Temp Sensor - 1985-1990 Thunderbird, Cougar - Motorcraft YH-434
eBay link: https://www.ebay.com/itm/Motorcraft-YH-434-EATC-ATC-HVAC-A-C-Temp-Sensor-1985-1990-Thunderbird-Cougar/184006024335?fits=Make%3AFord&hash=item2ad79d1c8f:g:8a0AAOSwONddsIIp
1984 - 1989 Lincoln Mark VII A/C Ambient Air Sensor - E4LY-19E642-A
eBay link: https://www.ebay.com/itm/1984-1989-LINCOLN-MARK-VII-A-C-AMBIENT-AIR-SENSOR-ASY-NEW-OLD-STOCK/133131113286?hash=item1eff3b9346:g:puMAAOSwqLFdQwhZ
FWIW, the factory sensor in my car looks just like the one in the eBay link that is listed for the Mark VII.
One of 1,246 built
Man! When I am parting out cars, I've just been throwing those away! I didn't know what they were.  Gotta keep 'em now!
Found the following:
https://www.thelincolnmarkviiclub.org/phpBB3/viewtopic.php?f=22&t=11677
EATC - Redesigned Replacement Control Head
AIR CONDITIONING - ELECTRONIC AUTOMATIC TEMPERATURE CONTROL (EATC) - SERVICE TIPS FOR REPLACEMENT OF
REDESIGNED CONTROL HEAD - VEHICLES BUILT BEFORE 4/21/90
FORD:1985-88 THUNDERBIRD
LINCOLN-MERCURY: 1984-87 CONTINENTAL
1984-90 MARK VII
1985-88 COUGAR
ISSUE:
The EATC control was redesigned in April, 1990. It has a center mode button labeled "VENT" and requires a new ambient temperature
sensor calibrated to match the new control. Using the wrong sensor will bias the interior temperature 5-10~ F from the set point.
ACTION:
If an old level EATC control head is replaced with a new level control head, a new ambient temperature sensor (F0LY-19E642-A),
identified by a white plastic body, must also be installed.
If a vehicle equipped with the old level control head (center button labeled "A/C") requires a new ambient temperature sensor assembly, use
(E4LY-19E642-A), identified by a black plastic body.
If the (E4LY-19E642-A, black body) sensor is not available, use of the (F0LY-19E642-A, white body) sensor will require installation of a new EATC
control head.
 I cannot confirm anything with regards to accuracy of that yet.....  Still hunting for the actual source as the person who posted it didn't cite anyone or anything.
*EDIT*
Might be from here.....
https://www.justanswer.com/ford-lincoln/7yps8-lincoln-mark-vii-lsc-1989-lincoln-mark-lsc.html
Answered in 17 minutes by:8/28/2013
Lincoln Mechanic: Don - Mo Lurch
sorry for the delay.............
The Ambient Temperature Sender is located Behind Center Of Radiator Grille under hood.
There was also a TECH Bulletin for replacing the Electronic Automatic Temperature Control (EATC)
The EATC control was redesigned in April, 1990. It has a center mode button labeled "VENT" and requires a new ambient temperature sensor calibrated to match the new control.
If a vehicle equipped with the old level control head (center button labeled "A/C") requires a new ambient temperature sensor assembly, use (E4LY-19E642-A), identified by a black plastic body.
If the (E4LY-19E642-A, black body) sensor is not available, use of the (F0LY-19E642-A, white body) sensor will require installation of a new EATC control head.
So the one for our cars (the black 84-89 one) is just a resistor and some other component. Figure out what they other component is and a rebuild is a simple 5 minute solder job.
That reads very much as if it was taken directly from a Ford TSB page.
One of 1,246 built
