Topic: 1988 EVTM (Read 7995 times) previous topic - next topic
1988 EVTM
Did this forums have the EVTM's scanned to look at wiring diagrams? I had a 1988 Thunderbird EVTM and for the life of me, I can not figure out where it is.
:burnout:
Re: 1988 EVTM
Thank you for uploading this. Trying to figure out why I have the center top mount brake light and no tail light brake light. Turn signals and hazards work perfect and no blown fuses.
Re: 1988 EVTM
@TheFoeYouKnow , I made a slimmed-down (file size-wise) version of the 1988 EVTM if you'd rather use that. It's about a tenth of the original file size, about 46MB total now vs. 465MB of the original.
https://www.coolcats.net/media/docs/1988evtm.pdf
Feel free to use it or link to it. At this point I'm willing to host anything like that.
Re: 1988 EVTM
Thanks Eric, that's actually where I ended up. I just assumed that I waa missing a fuse or a bad wire. When I crawled under to check fuses I found about 5 wires jammed into the fuse box with a bunch of splices. So I wanted a good reference if What it should have looked like.
Re: 1988 EVTM
Link moved? Not working anymore.
Edit: That was on reference to Eric's post. Forum quote isn't working on mobile apparently.
Re: 1988 EVTM
Sweet!
