Topic: Electronic Gauge Cluster Circuit Layout Needed (Read 2040 times) previous topic - next topic
Hey all,
So im making serious headway on my custom gauge panel but need some help since my car is in storage 20 miles away and I cannot reference it.
I need to know which circuits on the flexible circuit board go to where. (Like 12v+, turn signal, etc)
I am trying to solder aftermarket gauge wires and custom indicator lights into the panel circuitry so I can utilize the factor plug in harness and fuse block to simplify and streamline things.
Anyone got a picture or something?
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
Re: Electronic Gauge Cluster Circuit Layout Needed
Thank you. I have that printed out. But since I don't have the connectors in front of me, I don't know where their physical location is in relation to the circuit board on back of the cluster. Ill check later tonight but I don't think the housing or circuit board have the circuit numbers printed on them that match up to the plug?
