Topic: 87 TurboCoupe 5.0 H.O. Converted (Read 1563 times) previous topic - next topic
Hey everyone,
Need to downsize my life and reduce costs. I lost the garage I kept this in and I'm ready to let her go to a new owner. Pictures are in the Craigslist ad but I'll copy and paste the general info. This car runs flawless and pulls HARD. Healthy motor, trans and rest of Driveline.
VIDEOS of the car
- Most recent video https://youtu.be/YF49_sB_PBw
- With 18" Cobra R rims (Wheels are sold no I don't have them anymore) https://youtu.be/gDEDHxr4s3g
https://vancouver.craigslist.org/rds/cto...98222.html
The breakdown:
302 H.O. Conversion from a 1992 Mustang Coupe with approx 160,000 kms on engine 230,000 on body of TBird November 2015
New Custom built engine wiring harness, wire tucking was done at the time so nice CLEAN engine bay November 2015
5 Speed Tremec 3550 Transmission (Stronger than a World Class T5) serviced and sealed NO LEAKS February 2019
Custom Aluminum Driveshaft with new U Joints and Slip Yokes
Electric Fan Conversion
3G Alternator Conversion
Underdrive Pullies
Typhoon Upper & Lower Intake
C&L Cold Air Intake
C&L Air Meter
Autometer Monster 5" Tachometer
Pillar Gauges (Oil Pressure and Battery Volts I use to monitor Electric Fan)
4.10 Gear Ratio (Hauls the mail)
Rear Disc Brake 8.8 Axle rebuilt with new LSD slip discs (AKA the car does proper two wheel burnouts)
Firewall Adjuster and new Clutch Cable
New rear upper and adjustable ride height lower control arms (Just received, haven't installed yet)
Redone headliner and interior trim bits
LED in dash and much work done on electrical to fix what was broken
Grant Steering wheel with custom hardware and TBird sticker on horn button (Still have factory original)
Sequential tail light modification. You'll see in the video what I mean.
Custom dual Flowmaster exhaust with H pipe
Subframe Connectors
And on and on and on.. I will disclose the full list and history to serious inquiries. I have documented the whole history of this car with receipts for over $20,000. I also have a trunk FULL of valuable obsolete spare parts for this car that I'm happy to send with it.
The BAD
Cracked windshield
Cracked Dash
Couple dings in the paint from rocks and one scratch on passenger fender
Driver Seat has tear in vinyl
Power seats (both) stopped working
Passenger front rim I began the process of polishing and didn't finish so it's got some swirls if you look closely at it.
The radio and equalizer is original and intact but not working (I don't listen to the radio when I drive this, I listen to the 5.0)
$8500
Car is located in Vancouver, British Columbia, Canada
Call or text Jeff 604-727-6434
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
