Topic: Gas Door Failure (Read 3413 times) previous topic - next topic
Gas Door Failure
Did anyone else run into this dilemma with their gas door pull cord.
X
I went to put Sta-Bil in the gas tank and pulled on the gas door cord and it broke.
Gas Door Failure
Yep. Pretty common. About half the ones I've owned were broken.
Gas Door Failure
Yeah. I'm screwed when the lock solenoid fails!
Gas Door Failure
I have the same issue. Its on my to do list in the spring.a
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
Gas Door Failure
XXX
This is how I fixed my dilemma for under four dollars.
I bought a 1/16" cable around 20" long and the garage hardware at the local Ace hardware store.
Gas Door Failure
I really wanted the plastic coated cable but couldn't find any.
Measured the old plastic cord against the cable and added an inch and clamped the hardware to the cable.
Used my Dremel to grind down the stop end to fit inside the plastic part.
Works good and the cable will probably outlast the car. lol
Gas Door Failure
Brilliant!
Gas Door Failure
That's a good fix. I broke mine not too long ago.
