Topic: Rear End Noises (Read 7230 times) previous topic - next topic
Rear End Noises
Nothing I can tell that is wrong with the rear end itself, I'm thinking it has to be bushings or suspension, something along those lines. It'll be a while before I can figure that stuff out, this winter at some point. Thanks for all the help
Rear End Noises
What did the 8.8 come out of?  Does it have disc brakes?
Rear End Noises
It came out of an 88 TC, with disc brakes
Rear End Noises
Check you brakes and make sure you assembled them correctly ie the caliper not moving and clunking around. Did the shop put new axle bearings in? These would be the ones in the outer axle tube not the ones holding the carrier in the rear end.
Rear End Noises
Any update on this???
