Topic: 5.0 Mustang Parts for a 5.0 Cougar? (Read 2095 times) previous topic - next topic
Hey, Folks --
Apologies if I've missed another thread dealing with this or posted in the wrong section, but I have a 1987 XR-7 with the 5.0L standard output engine. All stock & only 46K miles, but age is starting to play a factor and I need to start replacing belts & hoses & probably some A/C system parts as well.
Will 5.0 Mustang parts work with this?
My intention to to get as many Motorcraft parts as possible to keep the car looking original.
When I look at places like RockAuto, the Mustang's Motorcraft part numbers are different from the Cougar's BUT sometimes the third-party parts lists OEM part #s and in there I often see both the Cougar Motorcraft # and the Mustang Motorcraft #.
Thanks in advance for any tips, suggestions & advice you can offer.
All the best,
Michael
As far as A/C compressors and clutches go the Mustang parts are the same. The hoses are different, as the routing is different between the two cars.
To the best of my knowledge, all of the hoses are the same. The serpentine belt is also the same.
The beauty of sharing this platform with the Mustang is that we are now able to jump on the "restoration parts" bandwagon.
https://lmr.com/products/79-93-Mustang-Radiator-Hoses-Heater-Hoses
If you have eatc, then the heater hose are different since there is a sensor in the way.
Although the belt routing is the same, the length is slightly different. Mustang uses a different length and there are minor differences in brackets.
Other then that, a bunch, like most any other part fits, but there are slight differences.
All of the hoses on my 88 Thunderbird are Mustang hoses.
Thanks for all the replies!
