Topic: I am making changes............again.... (Read 4969 times) previous topic - next topic
I have an Anderson N41 cam on the bench, and a Trick Flow Track Heat intake and spacer in route. The Trick Flow R has been too much intake for my car.
The Ed Curtis cam has been awesome, but it was made when I had a lot of different parts. I have since swapped the rear and the gear ratio, 3.55 to 3.73. I went from a 70mm throttle body to 75. Shorty headers to long tubes, and the GT-40 intake to Trick Flow, so, I think I'm going to swap the cam next Thursday, along with the intake and a new balancer. News as it happens along with pics.
Here I go again.
Soooooo, what do you do with your spare time Vinnie?      ��  It's an addiction we all live with so don't feel bad.
Spare time? What spare time? LOL
Vinnie how has the Trick Flow R been too much? Why the cam change? I can't believe you will gain a bunch with the N41.
For the cam, it was made when I had shorty headers, 70mm throttle body, 3.55 gears, GT-40 intake.........then I swapped to 3.73 gears, 75mm throttle body, Trick Flow R intake, and long tubes. The cam is really nice, but I felt that with all of the changes, it's not able to do it's job as Ed designed it for, so I found a stupid good deal on a brand new N41 cam and thought I'd try it. I talked to Anderson Motorsports, and they said with their cam, the R intake is better suited for racing and high RPM driving and I'd be better with a Track Heat or Holley Systemax intake.
I really wouldn't swap the intake. The Performer RPM I'm running is for "high rpm and racing" but it runs great on the  street. The car runs much better than it ever did with the GT40. With 3.73 gears you're not going to really notice a difference.
Vinnie,  what ratio RRs are you running? A simple swap from 1.6 to 1.7 can change alot.
Right now I'm using 1.6 roller rockers. The N41 info states that is what the cam is designed for.
As far as intake, I have the new Track Heat arriving today. I will try it out. If I don't like it, I can re-install the R intake. To be honest, I'm using the info that the Anderson rep was ttelling me when I called.
Is there an ET/mph you are going to compare the new vs the old combo against?  Stock compression/displacement shortblock ?
Quote from: Vintage;467124
My last time slips were with a different intake, gears, throttle body and headers. So, no current data to compare it to.
Bummer. Would have been interesting to see what the effort yielded at the track in addition to how it responded on the street. Hope it does what you want it to.
