Topic: Test Procedures Area (87 TC/5.0)? (Read 2312 times) previous topic - next topic
Been off the site for a while, but I would swear there used to be a section for (relatively) simple but common troubleshooting procedures?  The one I'm thinking of was the one to rule out fuel pump relay vs. fuel pump issues or EEC issues.  Did some searches but came up empty.  Already replaced the relay (cuz it was easy/cheap) but the tank/pump, not so much.  I'd love to narrow it down to the pump before I go any further.  All I remember is jumpering a wire on the passenger side kick panel to listen for the pump but I'm getting old and the memory is fading.  Thx
Mods, is this a workable idea or too much hassle?
James
http://turbotbird.com/techinfo/Fuel_System/fuel_system_diagnostics.htm
http://turbotbird.com/techinfo/Fuel_Pump/Fuel_Pump_Diagnostics.htm
